plastering over hard coat
Old 03-24-03, 07:36 PM
vesel
Question plastering over hard coat
we're redoing our kitchen ceiling and walls, we have an old house and now they have a hard slick coat on them. the bottom half of walls have the look of tile grooved in them. want to know how to prepare walls before plastering. thanks
Old 03-25-03, 04:33 AM
awesomedell's Avatar
Hi vesel, and welcome to the forum. Sounds like maybe you've got marolite, (probably spelled that wrong) on the walls there now.
If it was me, I'd hang 1/2" drywall right over that. Then you can either smooth finish it, or apply a textured finish.
Hope that helps you. If not post back & we'll see what we can come up with.
Old 05-07-03, 11:46 AM
vesel
plastering over hardcoat
i had previously asked about plastering over a hard coat that is in our kitchen and was told to put up half inch drywall, i don't really want to do that. just need to know how to do it on the hard coat
Old 05-08-03, 04:09 AM
If you're planning on using joint compound (drywall mud) for your "plastering" that stuff will stick to nearly any surface. If your wall currently has a real slick finish, you might want to rough it up with some sand paper before starting the mud coat. Sorry if I misunderstood the question the first time around, but what you were describing sounded like marolite panels to me with the brick pattern. Good luck.
