"Smoke" film on drywall
I installed drywall to a rental unit - cathedral ceilings - Tenant smokes heavily and burns candles all the time (don't suggest eviction, she's an inlaw)
There's a film on sheetrock - most notably the upper seams and screw heads are visible and look like black dots - you can't feel them - they're not popping - I'ts been suggested (by my brother a sheetrocker for some 25 years) that its a reaction to the wax from candle wicks and the excessive smoking. A contractor I know said he had this same problem caused by a tenant and sued them for it (and won).
You can actully feel the film - and trying to wipe with a damp rag just "smears" the film.
I'm hesitant to repaint as I feel the condition will continue as long as she's there, but hate to see the home in this condition.
Will KILZ or a similar product cover this? It's also been suggested that I use a product called fire brick (which I've never heard of) and "sand walls" with it.
I'd suggest getting the smoke film off the drywall before repainting. Two products I've found that work for this situation, I was just mentioning to Peggy another thread. Mean Green or Awesome, both will cut smoke film when used at a slightly dliuted strength. Best of luck. God don't you just love out-laws, I mean in-laws.
"Smoke" film on drywall calculate area?
So I should remove smoke film, apply a Kilz like product and repaint and throw out the in-law (I wish).
Is there any paint that is more resistant to this type of film or perhaps a high quality air filter/smoke eater (as they call them in bars) that I can utilize? The main floor is approx. 14 x 38 w/ cathedrals (I'm guessing) 14 - 15 ' to peak)
Any math wizards out there that can calculate the area so I can price appropriate size units?
I just about made it through basic college math!
Kathy
Kathy
An eggshell or semi-gloss would be easier to clean than a flat paint.
The room would be approximately 5580 cubic feet with a 15 foot peak cathedral ceiling.
The film is most likely from the candles since they gutter all the time.
Hi Kathy,
Here's a link to a good project calculator on the net. They have these set up for paint, drywall carpet, about anything. You just fill in the blanks as to width & height, etc click calc, & it does the rest for you.
http://www.improvenet.com/projecttools/calc/paint.html#
Good luck.
Good luck.
smoke film on drywall- Thanks
The calculator will really come in handy as I will (hopefully) be insulating/drywalling my garage to convert it to living space!
Thanks again - Kathy
1 Post
If worse comes to worse, you can paint Kilz directly over the smoke stain film., although it would be better to clean it off. I have even seen Kilz used to seal charred wood from a minor house fire (it worked).
Good Luck!
Mike
Good Luck!
Mike
