Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
repairing drywall after removing wallpaper
Old 04-26-03, 11:44 PM
tambamrob
Please i need help! I removed wall paper and damaged some of the drywall. The top layer of the drywall peeled away with the paper . Is there a easy enexpensive way to repair the this?
Old 04-27-03, 06:06 AM
You can apply a thin coat of drywall joint compound over the damaged area, sand it smooth with 100 - 150 grit sand paper, then prime the area. Now you can paint, if you so desire.
If just the surface of the paper is damaged and the sheetrock's white interior is not showing, you could prime over the damaged area. Once it is dry, it may be a little fuzzy. You can sand that off with some 150 grit sandpaper, prime again, then be ready to paint.
Hope this helps.
Old 04-28-03, 06:54 PM
awesomedell's Avatar
tambamrob
Hello & welcome to the forums. Follw Chris' advise, you'll do fine. Good luck.
