Stepped through the celing!
My ceiling is called "orange peel" it has peeks that looks like the paint/mud has dripped. I stepped through it and made a hole as big as my head. I've been told it's going to cost $250.00 plus to fix and I'm thinking I can do it myself for material cost. Any ideas on how to get the paint to match or do they paint the ceiling after mudding it? It's in the middle of the living room where a lot of sunlight comes in. The house was built in 1997. Please help!!!
Hi Ken & welcome to the forums. Walked thru the ceiling, Check out this page for links on how to deal with patching the hole & patching up the texture. http://doityourself.com/wall/index.htm
Post back if you still have questions. Good luck.
Stepping through ceiling!
Thanks for the web sight. It helped for putting up the dry wall, but now I need to know how to match up the paint. The mud dried a light shade of grey and the ceiling is white. The ceiling appears to be a flat white, but I want to make sure they match up when I go to paint the new area. Any ideas!!
Realistically, you will need to paint the entire ceiling. It is unlikely that the paint has not gotten dirty or faded since installed. Trying to paint a section with new paint in the midst of older paint will leave a section that likely will not match. Ceilings are usually painted with flat white latex paint. Put some primer over the repair, then paint.
Good luck.
Good luck.
Stepped through ceiling!
Thanks for your help on the paint stituation. I was hoping I wouldn't have to paint the entire ceiling, since the kitchen, den, entry way and hall way all connect. Bummer!!! I guess I'll hire someone for that job. Thanks for all your help. Ken
