90* Corners?
This may be a dumb question but here goes anyway...
I have just finished the second mud coat on wall seams and corners. I am planning , eventually, to put up wainscoting and corner trim but noticed that my outside corners are not close to 90*. Is this normal due to the corner bead, or do I need to keep adding mud until its 90 (this would make my miter trim cuts easier). I really don't want a large gap behind my trim b/c the corners are curved.
Any suggestions would help. Thanks.
In my experience, there are no 90 degree corners in a house. You can work toward this end, but may wind up with no support for the outside corner from the corner bead leaving a fragile corner subject to damage.
This will be straightforward to compensate for when you install the wainscot.
HTH
HTH
Mudder I think they mean that it is concave. In other words if you put your knife on the bead and the wall there would be a large gap. Keep filling with mud until the gap is gone.
Thanks to all for responses,
The walls are slightly concave due to the raised nature of the corner bead. I expected that the trim would be easir with straight 45/45 cuts for the outside corner. Unless I really load and feather the mud, it looks like I'll have to figure out the angles or fudge-it a little.
Thanks again
Thanks again
