lowering ceiling and even it up
My ceiling in my den has always been uneven, my kids and I did it ourselves. We needed at that time extra room despartely. I couldn't aford a carpenter. I'm tired of looking at the uneveness, even if other people dosen't notice it. I want to lower and even it up. I want to used drywall. I have ceiling tile as of now. Could tell me what materials I may need and give me how to instruction on this project.
Thank You,
Yvonne
Thank You,
Yvonne
lowering ceiling
I don't have a lowered ceiling. The ceiling tiles are stapled onto 4x8 wafer or some call it chip board, that is nailed to the ceiling joist. What I want to actually do is to lower the ceiling, which will only be lowered in certain areas to make it level and even. I was thinking maybe using 1x2's, since to even it up will not take more than 2 to 3 inches.
Yvonne
Yvonne
Why is the ceiling uneven? Is it the waferboard? It might do to take it down and install the sheetrock onto the ceiling joists, unless they are the problem with the uneveness.
Shimming furring strips to a level point would be a good way to go. They need to be attached securely to support the sheetrock. If the waferboard is the reason that the ceiling is uneven, attaching the furring strips may be difficult.
HTH
HTH
Shimming to level is a nightmare. If the cwafer board is out of level, remove it. If the joists are still out of level, attach a piece of 2x lumber to the side of the existing joist parallel to it and sticking down. Make the bottom of the 2x pieces level and attach new sheetrock to them. It goes a lot faster than shimming, and if you can use as many long pieces of 2x as possible gives a nice flat surface.
