Suspended Ceiling
's Avatar
04-18-00, 07:33 PM   #1
I'm putting up a suspended ceiling in a newly finished basement. There is a steel beam about 1 foot lower than the ceiling running the length of the room. I need some ideas on how to cover (disguise) the beam. I have thought of framing it in with sheet rock, but that is more work than I am willing to do. Any suggestions?
's Avatar
04-23-00, 01:47 PM   #2
Hi Torr, A suggestion would be to cover the beam with a three sided wood box. You could secure it to the floor rafters with plumbers tape or metal ties used for framing they make many different forms. The type of wood could be as diverese as oak for a classic look to rough sawen for a rustic look. Good Luck Woodbutcher
's Avatar
04-23-00, 03:32 PM   #3
Here is a link to some possibilities http://hometime.com/projects/howto/l...w3.htm#ceiling
In any case you need to build a soffit around the beam.
MTAC - Van Buren,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
Anything worth cutting down a tree for, is worth doing right.
www.toolreview.cjb.net
