Plaster Board Wall - Bulge
The person I bought my house from closed in what used to be the deck to form a sun room. They used plasterboard on the walls but didn't finishe it very well.
I have one section of the wall, near the doorway (which does not have the wood framing finish around it) which is between studs that has started to bulge outwards.
This particular section has no nails in and is about 5ft square (the middle of it bulging) it's about a foot from the ceiling.
What is my best option?
There isn't anything to screw it down to, that's the problem. The joists run along the outside of a 5ft sqare with the bulge in the middle of it. I can push it in and out as it is flexible.
Do I just nail it around the outside? Was there some reason this wasn't aready done?
I would make sure there isn't anything like an electrical outlet behind there that got buried. I don't understand though how 'plaster board ' could be flexible. Could it be that two pieces of drywall were joined and taped with no stud behind the joint??
If so you should remove this drywall from stud to stud and replace.
Thank you for your posts, looks like I will have to cut that area out and put a noggin behind to fasten the board to.
I also found out, as I had a tradesman around on the weekend to look at my roof (leaking!), that it is not actually plasterboard, it's a small section of 2 mill ply! Of all things! Which he's joined in and painted over.
Looks like the person who enclosed the room just did a bodgy job on this section of the wall (I've got hairline cracks all over the place) so I may have to re-do the whole side of this wall, the other side is fine and is made out of proper plasterboard.
