partiotion wall frame, how tight
Old 07-20-03, 11:57 AM
telefunken
how tightly should a partition wall frame fit into the existing ceiling joist?
should you have to use a mallet to get the wall to fit into the slot, or that's applying too much force and could potentionaly damage something.
Old 07-20-03, 12:37 PM
If it is in place, plumb, and square you should be alright.
Old 07-20-03, 02:59 PM
telefunken
is there any danger in fitting the wall against the ceiling joists too tightly?
is there anything you can use besides a saw to trim the 2x4s, its such a small fraction that needs to be removed, would sanding work?
Old 07-20-03, 08:56 PM
bungalow jeff
You do not want to fit a partition wall tight because it will act as a new support to the joist above and try to distribute additional load to the framing below. Cut the studs shy and nail with shims.
