ledger board
ledger board
hello,
my deck turned out find. In fact, so well that a friend of mine wants me to help her build her deck. My house is wood, whereas her's is bricks. How do I attach a ledger board to a brick wall? Do I use lag screws to or some type of cement screws?
Thank you,
Yvonne
Thank you,
Yvonne
Check with your local building inspector. A number of decks have been pulling away due to inadequate fastening causing injuries and deaths. Lag screws and lead anchors are not particularly strong in withdrawal and are prohibited in some places. Fastening to rim joists has even led to problems where the entire rim joist pulls loose. In these cases nails are loaded in withdrawal where thay have little strength. (Generally considered zero for structural work.) Through bolting to 2x blocking has been considered the best fix.
StephenS is correct. At that height there is no reason to use the house for any support. Drop the pier below frost or two feet then stand the posts off the pier with metal hardware. Evil Orange had it last time I was there. You will have no wood touching the ground and save a lot of trouble. The double bolts holding the rim joist/beam to the posts will provide lateral stability.
