Knockdown finish
Old 08-06-03, 09:51 AM
fsanchez
Knockdown finish
I don't know if this is the right forum to use and i amsorry if it isn't but I was not sure where to post this request.
Could anyone PLEASE.. Give me a quick virtual lesson on how to do knock down to my newly hung drywall.
Also anything I should look for or know before I start and while I am doing it..
Thanks
Old 08-06-03, 10:29 AM
T
Received 39 Upvotes on 32 Posts
First tape and finish the drywall as if it were going to be a smooth finish and sand.
Then spray the walls and ceiling with a finish made for this type of application. Before it is dry use a trowel or your taping knife to flatten some of the high spots left in the texture. That is all there is to it.
If you get a good job finishing the knock down will look good. Some finishers advocate priming the surfaces before you spray. For your first time at it this might be a good idea. It evens out the suction between the taped joints and the field of the drywall.
Old 08-06-03, 10:47 AM
fsanchez
So do you mean finish the entire wall using kilz2? also is there a certain amount of time I should wait between spraying and trouling? Like to let it dry a little?
Old 08-06-03, 11:12 AM
fsanchez
Oh yea I also wanted to ask if there are different types of tips for the sprayer. If so what determines the type I should use?
Oh and I jsut thought of another question... Is there a distance I should make sure to stand away from the wall?
So many questions!! I really hope I don't mess this up..
Old 08-06-03, 12:59 PM
coops28's Avatar
DONT use kilz!!! If you are going to prime prior to texture use flat laytex paint. How are you spraying your knockdown?
Old 08-06-03, 01:24 PM
fsanchez
I was planing on renting the sprayer from Home Depot..
Old 08-06-03, 02:37 PM
coops28's Avatar
There are different tips that come with the sprayer. small, medium and large. You probably want to use the medium. Also rent a 1/2 inch drill and mixing paddle if you don't own one. Mix your mud very thin. You will know if its too thick cause it wont spray. Spray a consistant, even coat over the entire surface. Wait about fifteen minutes(give or take with humidity and temp). Then drag your knife over the surface at a 25 degree angle with light pressure. Go across all tape joints. If you go with the joint you are likely to get a big long flat spot so drag across them. Thats about it. Let it dry and paint.
Old 08-06-03, 02:39 PM
coops28's Avatar
And to answer your final question...keep back about 18 to 24 inces away from surface.
Old 08-06-03, 02:42 PM
fsanchez
coops28.. I noticed you are in KC... I am in Overland Park... Hey do you do knock down?
Old 08-06-03, 03:16 PM
coops28's Avatar
Sure do. Check your personal messages for more detail.
