addition
Old 10-28-00, 03:28 PM
Cool
I'm not sure if this is the forum for this topic, but here goes.
I'm planning a 20'x 20' addition (master bdrm). The house is stucco over block w/ conventional framing for inside partitions on a concrete slab (about 6"). How should I frame the addition? Or should I do in block as the rest of the exterior? finishing is not a problem, as I can stucco over wood framing anyway.
Thanks for any input!
Old 10-29-00, 08:01 AM
Post
I would probably go with conventional stick framing (either 2X4 or 2X6) simply because it would be faster and less expensive. Millions of houses built this way have been standing for over a hundred years!
