Ready for paint
Ready for paint
Having started my basement finish project in February (actually I didn't start in ernest until March....) I am finally ready for paint.
Question is: after all the sanding of the joint compound, there is a lot of dust "stuck" to the walls. Obviously I need to remove it. What's the best way to do this? I have an air compressor (as in a big one for pneumatic tool use) - can I just blast the walls with 100 PSI of air? Should they be wiped down? Vacuumed?
I plan on using Benjamin Moore paint. It's expensive, but I've found that you get what you pay for. Should I use their primer as well? Any recommendations?
Thanks!
Jim
Thanks!
Jim
You can run a shopvac over the walls or wipe them with a cloth. Getting all the dust off is not that important. Blowing the dust off will make a big mess.
The wall should be primed with a PVA primer, before using that top of the line Benjamin Moore.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
Jim
