Inside hot tub
's Avatar
11-10-00, 10:25 AM   #1
What do I need to do, about the moisture and humididty, If I put a hot tub inside the house
's Avatar
11-10-00, 11:13 AM   #2
Humidity isn't the only problem. Think about the elevated levels of chlorine, ammonia, and hydrochloric acid also. Ammonia and hydrochloric acid (muriatic acid) are used less often than chlorine, but they are used. Key points: tile or plaster walls & ceiling, ventilation.
