Repairing drywall at window corners
I have severe water damage to the drywall at the two lower corners of an upstairs window due to leaky outside seals. I'd like to repair this damage in conjunction with replacing the window. However, I've never repaired this type of an area before since it involves 90 degree angles at the corner of a window. Should I make an L-shaped patch which extends to the floor? Any suggestions on an approach would be most helpful
Hope this helps.
