Removing ceiling Popcorn...
I need information on what tools/suplies it takes and how to remove the popcorn from the ceiling.
It is a messy job. Spray a bit of water on a section of ceiling and scrape the damp popcorn off. You will want to use a tarpaulin to cover everything. Let it fall into a old pasteboard box. Once it is done, let it dry, and repair any damage to the ceiling with joint compound and sand smooth. Prime and paint.
Hope this helps.
Hope this helps.
Use a 2 gal garden type sprayer to spray water. Spray a 5x5 area at a time. spray enough water on it to turn the area to a grey color. I like scraping off with a 6 inch knife. You have a lot more control and its not curved like larger knives. When you have it all off and its dry, sand the remaining off. Then start your repair of the seems.
