repairing plaster walls
Old 09-15-03, 12:18 PM
MegM
When I pried the icky wainscotting off the walls in my kitchen, I tore a lot of plaster off the wall with the window -- but no damage to the other walls.
1. Why just that wall? Could there be a moisture problem on that wall, since it has a window? Or did they just use an industrial-strength adhesive on that wall & not the others?
2. How easy is it to repair the plaster? Can I "DIY" this, or do I need to hire somebody?
3. What the heck am I going to use to remove the adhesive from the plaster on the other walls? This stuff is like cement!
Thanks,
Meg
Old 09-15-03, 12:27 PM
coops28's Avatar
Get a good scraper and scrape off remaining glue. Remove all loose plaster. Fill in with drywall mud. let dry. Cover entire patch area with mesh tape. Cover tape with 3 coats drywall mud feathering out smooth.
Hard to say why it came out under the window. Moisture seems like the most obvious
Trackbacks are On
Pingbacks are On
Refbacks are On
