Texturing over wood
Texturing over wood
I recently bought a house that has a three stall detached garage. The garage has avery nice loft above it. I would like to make the loft into a game room. The walls are just plywood or particle plywood. Is it possible to just texture over the wood instead of hanging drywall? If texturing is the best way...any recommendations on material to use?
You could texture over it. First you will have to prime the wood with stain blocker. then you will have to either tape the seems, like drywall or trim them out with moulding. Maybe you should just paint the plywood?
