repair wall?
repair wall?
I recently removed wall paper from a bathroom and the first layer of the sheet rock came off. It's a gray paper showing through. How do I repair this, so that I can paint?
It can be quite a chore to get all the wallpaper and glue off the wall, as you have learned. Some damage is inevitable.
Prime the damaged area with a good primer - sealer, such as: Zinsser 123. If there are any fuzzy sections afterwards, lightly sand them smooth with 120 grit paper and prime the sanded area again. Then paint with a top quality paint.
Hope this helps.
Hope this helps.
The picture below is the disaster to my drywall after removing the dark paneling that was there. The stripes are panel adhesive that in places is 1/4" thick. I hired a drywall professional to "putty fill" this wall. He did three coats, letting the previous one dry throughly before applying the next one. He put up a plastic curtain and applied "orange peel" texture. The job turned out perfect. You could sure try this yourself, especially in a small area like the bathroom.
http://members.impulse.net/~dmaxwell/drywall.jpg
If you are not set on painting there is a very inexpensive way you can go *around*having to repair the wall.
I had the same problem and then learned about brown bagging. The actual horror spots in my wall ended up disappearing...I have had so many compliments and it takes very little talent or money! : )
I dont have time to explain it now, but if you want me to tell you more just email me : )
Jade
Jade
