Anchoring Studs
Anchoring Studs
I'm building a frame with 2X4's that will go on a basement wall (cinder block) so I can hang drywall. I plan on nailing the top part of the frame to the studs in ceiling. At the bottom, I plan on using shims (I'll be building the frame on the floor and raising it to the wall). If the frame is sufficiently built, will that be enough support, or do I need to anchor to the cinder block and floor? If I need to anchor to the wall/floor, what kind and how long should the nails be. And, if I anchor the top and bottom part of the frame 1st, what's the best way to put the vertical studs in? The wall is about 27' long. Also, I know 16" is the recommended distance between vertical studs, but can I extend that a little without jeopardizing the quaility look of the drywall?
1 Post
wall
Use green wood for the bottom plate. Yes you can go 24" on centers for the studs. Put up a 2 mil-poly on the block wall then the stud wall. Dont go into the blocks, anchor at the top to the joist and the floor. Put the G/W on the floor and shims at the top. Build the whole wall on the floor then lift it up. 16p for the stud nails
ED
morgan
What is a 2 mil-poly? There is currently a clear sheet of plastic on the wall that I assume is from where there was water damage years ago. Cement floor (in corner) has also been redone with probably a drainage pipe put in the floor and there is hard plastic going up about 8" from the floor.
