Texture finish on drywall is peeling off
I noticed some bubbles in the texture finish on the drywall in one of my bedrooms. When I pushed on the bubbles the texture just peeled of in huge areas - 3 to 4 feet in some sections. The paper on the drywall is still there, it's just the texture finish that peeled off. The walls had previously been covered with wall paper several years ago. When I removed the wallpaper I primed the walls before I painted them. Is the wallpaper adhesive the cause of this? If I have someone respray the texture finish how do I prevent this from happening again? I'm also worried that the texture that is still on the drywall will bubble after the new coat is applied. I appreciate any suggestions.
What kind of texture do you have? Interesting dilemma you have. I have seen texture come off due to excessive amounts of dust. In other words the texture stuck to the dust not the wall. Have you had any water damage? The paint didn't hold either right? since you peeled it off? Thats whats peeling off. Maybe your primer failed.
House was built in the '70s, right, no big deal, scrape off all the old texture, check all sheets to insure still securely hung. Look for nails that have pulled slightly, etc. & repair as necesary. Skim coat the entire area, light sand, then wipe with DAMP sponge to remove all dust. Put on a coat of sealer/primer, then reapply desired texture finish. Most likely just an accumulative effect from yrs of humidity, etc. My $.02 worth, which has gotta be worth the price charged.
