Ceiling Max System
Ceiling Max System
Just wanted to know if anyone out there has any experience with Ceiling Max? It's a non-drop grid system that goes directly on the ceiling joist. I'm putting in a ceiling in my finished basement and do not want to lose any ceiling height, but want to have a removable tiled ceiling. Any other ideas that might help would be appreciated.
Personally have never used this or even seen it installed but I do have a few thoughts. Looks good and very easy to install but...very rarely are ceiling joists level or straight. So if you screw the grid right to the joists your ceiling will follow right along with the curves and waves of the joists thus making your final product look pretty bad. Another draw back is you will have to box around anything hanging down from your ceiling like heat/cooling ducts, plumbing, gas pipes etc... So unless you have a really open straight space and all you like is access, this is for you. Personally if I have to box around all that stuff I would hang and finish drywall or just install a traditional drop ceiling.
Received 0 Votes
