Wall Texturing
I am going to be applying a skim coat and re-texturing several walls in my bathroom, and one in the entryway. This will be the third time I have done the entry! I have not been very successful at creating an "orange peel" finish. The texture is very rough and doesn't match the other walls. I have used a hopper and the smallest opening on the gun, but the texture size never comes out consistently. In the past I have used pre-mixed texture products. My experience has been that this is too thick and may be a contributing factor to my problems. This time I plan on using a powder and mixing it myself. Am I on the right track? What about distance away from wall? (2 feet?) Any suggestions? Thanks!
Hi Chris and welcome to the forum.
I don't recommend the powdered junk, just a real pain to ever get it mixed enough to use for texture mud. I use lite compound or else topping mix in a bucket and either way it must be thinned with water down to a consistency of running oatmeal. Once you've got you're mud to the right soup mixture, push you air pressure up to about 80-100 psi, set the hopper to a medium hole size for the spray, now you load her up and start spraying, you want to be about 2-3 ft from your wall. I apply a liberal thick coat, then give it a few mins on the wall and come back over it with a wide knife or better yet a paddle. What I use for this is actually a painter's screen, this is a wide thin piece of fiberglass on a handle.
Best advice I can give you for matching existing texture on a wall is to practice on a piece of scrap drywall until you've got what makes you happy & then start on the actual wall. Post back if you've still got questions and we'll have some answers for you. Good luck.
Unfortunatley, Chris, Orange peel texture is the most difficult texture to match. It takes a very steady hand and you have to be super consistant. You may have to bite the bullit on this one and hire a professional to help out. Other than that Awesomedell has given you some good info. Also consider leaving the bathroom completely smooth and skim out the entire entry. As a general rule you like to keep a consistant texture throughout your house but if you have definite room breaks it wont be bad.
