uneven floor/window and door openings
Old 11-25-03, 07:04 PM
telefunken
im framing a wall in my basement that has a window and door opening. my floor is somewhat uneven, to point of one side of the window opening is off by 1/4"
should i build the opening with 1 jack stud 1/4" taller then the other, compensating for the slope in the floor, or should i just build everything the same size, and shim the window more on one side after the fact.
same question in regards to door openings.
Old 11-26-03, 05:51 AM
awesomedell's Avatar
I'd make the window & door openings square to the wall and worry about the level on the floor when you get ready to do the flooring.
Old 11-26-03, 10:48 AM
brickeyee
The sooner you make the work level, the easier the next stage will be. I would make the trimmers uneven and align the framing with the window. This is one of te things that makes remodeling go slower than new construction.
