want a arch
Old 12-03-03, 03:24 AM
tad214's Avatar
john 3:16
Talking want a arch
hello,
i have added a wall within my house. now here is the question, in the doorway, my wife wants the top of the door to be an arch.(sheetrock). could anyone give me any tips or hints on doing this. the cheapest way might i add. lol thanks in advance for any assistance.
i was advised by tn andy, up in doors and windows, that awesomedell may be able to give me the run down on how to do it
You might check down in Walls/Ceilings with AwesomeDell, as he is more of a sheetrock specialist.
thanks a lot for any help.
Old 12-03-03, 04:25 AM
awesomedell's Avatar
Easiest way is to cut the rock to fit the size than the arch top. I suggest 1/4" rock for this purpose, then soak it in water. When I go into a remodel or new construction with archways. I do this first thing, as the rock for the arch will need to soak for awhile until it's pliable. Once you got it soaked up, carefully take it out of the water and bend it into the approximate arch desired, now take a piece of twine and tie around it to hold the piece in the arch shape. Now let it dry completely, when it's completely dried, remove the twine and and fit the piece into the arch top and screw her down, I never use nails for this purpose.
Now add the straight legs to go up either side of the doorway to the beginning of the arch. You should have both sides of the wall rock already done before you start on the arch.
Couple of ways to finish the arch, the easiest would be to use a vinyl flex bead, most likely have to get it from a drywall supplier, other option would be to use flex-tape, this is a paper faced metal tape that comes rolled up in a box, this is widely available from home centers or lumber yards.
Hope that helps you out.
Old 12-04-03, 06:07 PM
tad214's Avatar
john 3:16
i could not have been told anybetter by anybody. thanks a lot. you been excellant. merry christmas to you.
Old 12-05-03, 04:13 AM
da nada,
Happy Holidays to you my friend.
Old 12-06-03, 01:54 PM
schlitz100
check this site out for kits
http://www.curvemakers.com/
this is a future project of mine as well
Forum Monitors Note:
The web site link provided does not specifically provide the information the member is asking for. The members question pertains to curving the arch way,, not installing one.
Nor does the link belong to the member providing the information.
But the link does provide help to members who are reading this question if they are seeking kits to install dorrway arches.
As a result and for overall benefit to all concerned parties, the link shall remain.
Reminder, no ads or advertisings are allowed, if such are provided no helpful information or are included with the sole intent to sell ones products or services.
Sharp Advice
Forums Monitor
