bathroom ceiling
Old 12-22-03, 08:54 AM
incaica
Question bathroom ceiling
can i use plywood first then apply plaster , to repair the bathroom ceiling? or do i need to use drywall? can someone let me know?
thank you very much and happy holidays!
Old 12-22-03, 12:04 PM
awesomedell's Avatar
incaica,
Hello & welcome to the forums. What is the situation you're trying to repair and what caused the damage? A few more details would help us give you some pertinent advice, but as a rule, you don't use plywood under plaster. Happy holidays!
Old 12-27-03, 09:30 PM
incaica
it's å båthroom ceiling- and wåter was the source of the dåmage. probåbly a leaky roof. the owner left å bunch of pieces of pieces of drywåll behind. we could use those if they're cut to fit the spåce?
Old 12-28-03, 08:47 AM
I'd use the drywall to patch-up the damaged area. It sounds like maybe the old ceiling is maybe plaster & lath? If that's the case and you've got any significant area to try & patch up, probably best to just pull all of the plaster & lath off the ceiling and replace it with a drywall ceiling. While you're there, I'd highly advise adding a vent fan in the bathroom if it doesn't have one.
If the old ceiling is drywall, then cut back the damaged area and patch in a like-sized piece of drywall, key thing is to insure what your patching with is the same THICKNESS as the original, drywall ceilings are usually 5/8", make sure you've got is the same.
Hope that helps out & Happy New Year.
There's links to tutorials on repairing drywall on this page;
http://doityourself.com/wall/index.htm
Old 12-29-03, 05:12 AM
coops28's Avatar
Good advice from Awesomedell, as always. What type of texture do you have?
