How to stop squeaks in floor?
Old 01-05-04, 10:12 AM
Hello,
I couldn't find a Flooring forum, so I thought I'd post this here. I've got a 2.5 year old house. In 1 bedroom on the second floor there are some spots on the floor that make a loud squeak or popping noise. How can I stop this? The floor has carpeting and I can't get to the underneath since it's on the 2nd floor. Thanks in advance.
Mark
Old 01-05-04, 11:57 AM
Im not sure what everyone else does.....but i take a 8 penny nail and pound it through the carpeting into the joists. use a punch to sink it flush with the wood.
finding the joist is a little tricky though. might take 2 or 3 in various spots.
Old 01-05-04, 12:41 PM
Does doing this ever cause a problem in summer when the wood might try to expand? And does this harm the carpet at all? I just don't want to cause more problems I guess.
Mark
Old 01-05-04, 01:47 PM
coops28's Avatar
I've seen some who put a screw all the way through the carpet into the floor joist as well.
Old 01-05-04, 02:55 PM
Dave_D1945's Avatar
I've seen a special screw made to break off just below the surface when it's screwed in. They're made just for this purpose. Try looking for McFeelys web site. They sell just about every kind of screw fastener known to the civilized world.
Old 01-06-04, 01:12 PM
Mark
the noise is from the underlayment/plywood not sitting all the way down on the joist...caused by not enough nails or a nail that worked loose. nothing bad will happen. unless you put the nail through a water pipe, or a live wire.
Old 01-06-04, 01:26 PM
Dave_D1945's Avatar
You make a small hole in the carpet when you do this, but if you separate the carpet tufts to drive the screw, you should be fine.
Floors squeak because nails have loosened over the years and that allows movement. The squeaking you hear is a board rubbing against another board or against the loosened nail.
Yet another reason to lay subflooring with glue and screws and leave the nails in the truck.
