Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Walls and Ceilings
Reload this Page >
Drywall: Put up ceiling or wall first ?
Old 01-11-04, 10:00 PM
AngryAmish
I'm doing my basement. Is it better to put the ceiling first or the sidewalls ? Right now my basement is all in cement. To build the wall, should I use 2X4 or 2X3 ? My floor is straight.
Thanks
Angry Amish
Old 01-12-04, 04:41 AM
mudder
definitely put cieling up first unless you put accoustic tiles on cieling (recommended)
You can use 2x4 or 2x3 your choice but make sure the framing allows 1/2 inch airspace between concrete and insulation and framing. put R13 insulation between studs and 6ml poly vapour barrier over walls on warm side (inside) finish with drywall or paneling.
Old 01-12-04, 05:29 AM
awesomedell's Avatar
AngryAmish
Hello & welcome to the forums.
I agree with mudder completely almost, only exception would be if you live in an arid area, you can forego the poly and I like drywall ceilings myself.
Old 01-12-04, 08:47 PM
AngryAmish
thank you gentlemen
