confused
Old 01-13-04, 10:27 AM
ozchick
Question confused
PROBLEM ONE
I have a wall which had z-bricks on it, which when removed have torn some of the drywall. There are patches where it is torn to the grey layer beneath.
Do I sand away uneven spots, then seal it or do I sand away then just apply joint compound. I want to texture the wall slightly and then paint it.
PROBLEM TWO
On the other walls in the same room, I removed wallpaper and am left with a shiny layer that looks like old paint (primer, am I right). In some areas a couple of layers of this "paint" peeled away. Do I sand them and apply joint compound, then primer, then paint. I want a texture on these walls too, then paint it.
THis is all in the same room. I want a faux finish- to hide any flaws, so that's why the texture would make it a bit easier.
Thanks for any help
Old 01-16-04, 05:50 AM
awesomedell's Avatar
Sounds like you've got the right idea, go for it.
