discoloration in walls
bub3683's Avatar
01-20-04, 08:19 AM   #1
bub3683
5 year old house showing discoloration, shadowing where studs are. Paint job is original, one coat, flat white---minimal coverage by the contractor. I'm looking to repaint, but want to make sure there is not an issure. Is it the quality of the paint job, or is there a deeper issue?
coops28's Avatar
KS
01-20-04, 01:35 PM   #2
Maybe it's just a bad paint job. Maybe it's a bigger problem. Do you have at least 1/2 inch drywall on the walls and ceilings? Are your studs 16" on center? One coat of flat white is not a good paint job.
bub3683's Avatar
01-22-04, 10:06 AM   #3
bub3683
yes, drywall is 1/2 inch, studs are 16" O.C.
PenguinDave's Avatar
01-22-04, 01:04 PM   #4
I am willing to bet this is on the exterior walls only. If so, then it is something called ghosting which results from thermal bridging. Much more likely on steel framed walls than wood framed.
Good summary at:
http://www.joneakes.com/ca/hs/cgi-bi...ahs.cgi?id=609
bub3683's Avatar
01-24-04, 12:08 PM   #5
bub3683
It is on the outside walls. And I live in the Northeast. I'm planning to repaint. It there anything I need to consider before hand?
