Rounded ceiling/wall joint
I am currently doing a remodel on a kitchen/dining room area, and in the process have removed a wall that seaprated the two. Originally, the dining room had a stucco-like wall covering that included a radius where the wall and ceiling met. It is about a 3" radius. Now, I have to make a connection on where the wall of the dining room now connects to the wall in the kitchen, where there is no radius. I would like to avoid having to remove the radius in the dining room.
Does anyone produce a pre-made "cove" that I could install along the ceiling to duplicate the original one?
Thanks
Brian
Thanks
Brian
Check with a drywall supplier, you can get a vinyl inside corner bead that will match up with what you've got. You'll won't find this item at a home center or lumber yd. Look up drywall supplys in the local ph book of the nearest large city & they'll be able to help you out. Good luck.
