Base molding
Old 02-04-04, 10:29 AM
Base molding
Hi-
I hope this is posted in the right section. Anyway, I am finishing my basement, which has 2x4 wall studs and 1/2" drywall. I want to put molding around the base of my Pergo and carpet, and this molding will likely be about 1/2" to 3/4" thick in order to cover the 1/4-1/2" expansion gaps for the Pergo flooring. My buddy has a framing nailer, but the longest nail it will accept is 1 1/4". Is a 1 1/4" framing nail long enough for my 1/2" to 3/4" thick base molding? Or does the nail have to be long enough to go through the 3/4" molding, the 1/2" drywall and set into a stud? Does base molding necessarily even have to be nailed into studs?
Thanks,
Steve
Old 02-05-04, 05:13 AM
coops28's Avatar
Your base has to be nailed to the studs.
Old 02-05-04, 06:17 AM
Dave_D1945's Avatar
Your base molding needs to be nailed into a stud or the bottom plate of the wall. Drywall doesn't hold nails worth squat.
Rent or borrow an 18 ga brad nailer and use 2" brads.
Old 02-05-04, 07:38 AM
Thanks
Thanks for the info.......
