crown molding & jigs
1975's Avatar
02-12-04, 07:00 AM   #1
1975
Does anyone know if any of the crown molding jig systems for mitiring with out coping will actualy work?
http://www.rockler.com/findit.cfm?page=10565&sid=AF998
Will I still wind up coping?
Thanks
coops28's Avatar
KS
02-12-04, 01:04 PM   #2
I have no experiance with that particular system. It look like you will have to cope still.
Dave_D1945's Avatar
02-12-04, 02:14 PM   #3
I guess that setup would work if you were dealing with exact 90 degree angles. The problem is that those are pretty rare.
1975's Avatar
02-17-04, 06:58 AM   #4
1975
Just used it this weekend. Results are okay if you're going to paint molding (which I did) and you can calk in the gaps. If you going to stain I think the results wouldn't be acceptable.
My results would have been better if I would have used a compase and cut angles that were closer to the actual instead of 90's.
Another lesson learned is to make sure your molding is good, I bought some from Lowes at $30 an 8' section and there were some serious issues with straightness.
Hope this can help someone else.
