Rim Joist Repair
Old 02-16-04, 04:37 PM
McEX
Rim Joist Repair
I have a rim joist that has some water damage and a few small areas of rot (which lead to some carpanter ants) due to a previous owner attaching a deck ledge without flashing. The rim joist is still in good enough to brace the ends of joists.
I have added flashing to the ledger to stop water infiltration.
What would be considered an acceptable fix for the rotten areas?
Thanks
Old 02-17-04, 06:26 PM
awesomedell's Avatar
Couldn't say without seeing how extensive the damage is.
Old 02-27-04, 09:11 PM
A lot depends on your nit-pickiness and the accessibility of the rim joist.
I am picky enough to seriously consider the following IF the access was adequate:
Go under the joists and set blocking/bridging to hold the joists in place.
Get a SawzAll with a 12" rough-in blade and cut off the rim joist nails.
Attach a new rim joist, perhaps using screws and plenty of caulk. Keep your sledge hammers nearby.
OR
Temporarily attach scrap blocking to cover each side of the damaged areas.
Drill a hole in one block of each pair, I can't say if top or bottom is the better location for the hole. Inject Great Stuff foam.
Remove the blocks in a few days.
