Building a stool wall (partition)
Old 03-11-04, 05:46 PM
amd
i am currently trying to build a stool wall partion out of plasterboard and wood
although i am unsure on how big the spacing shouold be between each length of vertical timber (in the stool wall)
and what size timber should i use, i have been told to use 2"x4" but this seems quite heavy considering the wall i requre is 9 feet in length
there will also be a door required in the wall but no window and it is not going to be supporting anything above it
mark in the united kingdom
Old 03-12-04, 02:44 PM
coops28's Avatar
Here in the U.S. most all partitians are made out of 2x4's and spaced 16" center to center. The actually measurement of a 2x4 is 1 1/2" x 3 1/2".
Old 03-12-04, 05:51 PM
amd
so you have 3 joists per board, what sized joists areused though 2 inches x 2inches
Old 03-14-04, 06:48 AM
awesomedell's Avatar
As Coops said here in the USA, framing standards would require a stud every 16" o/c. So for a 9' long wall you would use a total of 9 studs, (2"x4"s) We normally build the walls laying down & then simply stand it up into place, check for plumb & square & then anchor into place.
Hope that helps out. Good luck.
Old 03-14-04, 08:08 AM
amd
i understand that much but the 9 wood studs what dimentions are they are they pieces of 2inches by 4 inches or 2inches by 2 inches??
please look at picture as it describes what i want to do alot better
Old 03-14-04, 08:11 AM
amd
trying again to attach file
Old 03-14-04, 08:20 AM
amd
hosting it here instead: Click here
Old 03-14-04, 08:40 AM
Mark,
I would use what are referred to here in the US as 2"x4"s, actual dimensions of the individual pieces are 1 1/2" x 3 1/2" as coops posted earlier. You would subtract 3" from your 6.6' and cut your studs all at that length.
So a 9.33 ft x 6.6 ft equals a wall, 112" long by 79-1/4" tall. If this is correct your wall studs should all be cut at 76-1/4"
Hope that's the info you're looking for.
