03-14-04, 11:12 AM
kfrank
rubber stripping on bottom of drywall
What is the best and quickest way to remove the rubber stripping on bottom of drywall, without having to peel off any drywall?
Kelvin
Kelvin
03-14-04, 06:41 PM
kfrank
Originally posted by coops28YES
Drywall doesn't have any rubber stripping on it. Do you mean the flat rubber commercial base board?? I'm not sure.
MO
03-14-04, 07:20 PM
That stuff is usually put on with either mastic or liquid nails, both are pretty hard to remove w/o damaging the drywall. You could try a heat gun, but can't vouch for the results. I generally use an old drywall blade & just figure on some low skim work to smooth things back out. Good luck!
03-14-04, 07:43 PM
kfrank
Thank you I'll try that. I figured a drywall blade would probably do it and I also figured on trying a heat gun. I was just checking to see if there is an easier more technological method. Oh well....
03-15-04, 06:51 AM
Everytime time we pull this type of base, it brings part of the wall with it. I tried using a heatgun once, found it would take about 30 minutes per linear foot to loosen the mastic. And the base started melting way before that. I wish there was a better way, but haven't found one yet.
