damaged, cracked and stained walls
Old 03-25-04, 11:56 AM
kellieparker20
I have cracked and stained drywall in several rooms. Possible water damage. How do I fix the leaks and walls?
Old 03-26-04, 08:27 AM
coops28's Avatar
You have to figure out where the water is comming from first and fix that. It's either a leaky roof or leaky pipe. Good luck.
Old 03-28-04, 04:23 AM
awesomedell's Avatar
If it's in several rooms, my bet would be on a leaky roof. Good place to start the process of looking for the culprit causing the leaks. Unless it's a multiple story dwelling, or the damage is in a basement lid, odds are good this isn't a leaky pipe, but who knows without more info.
