Plastering over greenboard or durock cement board
supdawg's Avatar
09-05-04, 02:25 AM   #1
supdawg
For whatever reason, I can't seem to find blueboard in any of the home improvement centers in my area (Los Angeles, CA).
I do have several sheets of greenboard and durock on hand, along with some metal lath. I was going to drywall an interior wall I reframed, but decided I'd like to go with plaster for it's added durability.
Can I plaster over greenboard or durock cement board? Is there any reason why I can't? If cement board is supposed to be waterPROOF, as opposed to greenboard which is waterRESISTANT, why can't I plaster over cement board? Does it have to be blueboard, which I can't seem to find anywhere?
Thanks,
Jason
Snoonyb's Avatar
09-05-04, 06:08 PM   #2
Blue board is not used there, instead gypsum lathe, which follows button board in the platering evolution, is.
The answer is yes.
coops28's Avatar
KS
09-06-04, 02:49 PM   #3
Blue board is treated with a plaster bonder. If you plaster over regular drywall, then you need to roll on or spray on a bonding agent.
supdawg's Avatar
09-06-04, 08:07 PM   #4
supdawg
Posted By: coops28 Blue board is treated with a plaster bonder. If you plaster over regular drywall, then you need to roll on or spray on a bonding agent.
Is that the only difference? I thought the gypsum core was also different. I have some bonding agent, but since it's liquid, how will greenboard or cement board react to having the bonding agent rolled on?
Thanks,
Jason
coops28's Avatar
KS
09-07-04, 06:08 AM   #5
The green board will do fine. I don't know about cement board. Personally I wouldn't use it.
