Identifying a load bearing wall
Old 09-10-04, 07:26 PM
I've been building a new closet into my bedroom, and just started knocking down the old closet.
I tore down the drywall, and noticed a double top-plate in the lumber behind the drywall. Here's a photo of the top-plate:
http://www.antunkarlovac.com/stuff/double_top_plate.jpg
... and here's a picture of teh wall itself:
http://www.antunkarlovac.com/stuff/is_load_bearing.jpg
All along I though that this must be a partition wall, since the way it's laid out looks like an afterthought.
Is there any way I could tell for sure if this is load bearing? If it is, what are my options?
Thanks in advance,
Antun
Old 09-11-04, 04:15 AM
In the attic, if there are horizontal framing members ending on, or joined over, are roof bracing ending on it, its a bearing wall and will require a header.
Old 09-13-04, 01:21 PM
Thanks - It turned out to be load bearing after all. I couldn't get to the attic space at first, but my neighbor (who's pretty knowledgable on construction) came round adn confirmed it. Then when I drilled into the attic space, I found the lapped beams.
My house is still standing after all.
-Antun
Old 09-13-04, 03:07 PM
Of course it is, you have only removed the wall covering, not the structure.
Do you need further assistance in installing headers or temporary support walls?
