how many screws in ceiling drywall?
dub's Avatar
09-15-04, 05:42 PM   #1
dub
I'm drywalling the ceiling in my basement. Using screws with 4X8 ft 1/2 inch drywall how many screws should be in each sheet?
Thanks,
Snoonyb's Avatar
09-15-04, 08:29 PM   #2
8"oc. in the field 1 ea. joist ea. side at the edges and 9ea. each sheet at the end joints.
coops28's Avatar
KS
09-16-04, 06:13 AM   #3
Most code calls for one screw every 12 inches in the field and 8 inches on the butt joint. And of course around the perimiter. Thats 5 screws per joist. So depending on how your sheet hits the joists, between 30 to 40 screws.
homebild's Avatar
09-17-04, 02:02 PM   #4
Irc 2003
Posted By: dub I'm drywalling the ceiling in my basement. Using screws with 4X8 ft 1/2 inch drywall how many screws should be in each sheet?
Thanks,
IRC 2003 says 1 screw every 12" where the joists are 16" or 24" on center where no adhesive is used...and 1 screw every 16" where adhesive is used...
So between 28 and 35 screws per board depending on adhesive.
Check your local code.
