Cutting outlet holes in drywall.....
Old 09-29-04, 07:57 AM
Hi,
I'm going to do a refinish of some basement rooms that includes drywalling. Through this forum, I've got great advice on framing & insulation. As a test or learning experience, I insulated and drywalled my workshop first - I didn't care if it wasn't perfect, just a way to see if I was up to the job. I learned lots of stuff - mostly to use a strong light when sanding - what I thought was a good job wasn't so under the glare of harsh lights.
Another problem I had has me vexed - that is cutting out holes in hung drywall for outlet boxes, etc. I first tried a little hand saw and while that produced decent results, it was slow. A friend lent me his RotoZip tool - now that is a nice tool! The problem is I had a problem making a consistently square hole that was close to the (blue) box. How do people get the hole close to the outside of the box? I tried using a 'feel' method - the problem is I ended up chewing into the box a bit (I wish the bit was round near the end, that would make following the box easier). I suppose that a pro gets a feel or do people draw out a box around where they think the box is? I tried this but I made the box too big so my electrical outlets don't fit well.
When I use the tool, I'm running it like a router (counterclockwise) but I hope to to a better job making a clean, accurate hole.
Bob
Old 09-30-04, 03:21 AM
awesomedell's Avatar
You need to use guidepoint roto-zip bits for cutting drywall. What I have new guys do is to just cut out the outlets to the inside dimensions of the box & then finish cutting it to outside dimensions. Boxes should be mounted on wall so they clear the stud by 1/4" or so for better cutout as well.
Old 09-30-04, 10:29 AM
Thanks - Awesome!
I'll take a hike to my local store to see if they have these. I imagine the end of the bit has no cutting edge, right? So I imagine the depth of the bit is deep enough to penetrate the drywall, plus a little more so the end of the bit rides on the box. Sounds great!
Old 10-03-04, 05:34 AM
Yeah the ends of the guidepoints are smooth, so it rides on the box without damaging it if you're running the router correctly.
Old 10-03-04, 06:38 AM
Thanks for the feedback!
