Drywall over plywood?
cjdarcy's Avatar
10-25-04, 12:12 PM   #1
cjdarcy
I'm enclosing and finishing a sunroom. Currently, the walls are 3/4" exterior grade plywood. I want to finish the walls with drywall. Can I put drywall directly on top of plywood or do I need to remove the plywood?
coops28's Avatar
KS
10-26-04, 05:40 AM   #2
If you are satisfied with the insulation and electrical then go right over it. It will be a little easier cause you can't miss a stud while screwing
