Help!! Drywall Removal
Hi, there,
The Florida hurricane storms got us, and good.
Can anyone tell me the easiest and most productive way (without hiring anyone -haha) to tear out drywall (ceiling too) and what tools to use? I've started with a hammer (using both ends) a screwdriver and a razorknife.(which doesn't cut deep enough with my strength)
It's all working but slow -ly and piece by piece. Any suggestions???
I'm sure I will need more help along the way,,lots to do.
but I'll be learning..
thanks, S.
thanks, S.
Sheryleen, Welcome to the DIY Forums.
You can rent or buy a reciprocating saw (commonly called SawZall). Use a 2" or 4" Blade. It will start through the drywall by putting it on an angle and slowly raising the back end of the saw. Once you hit a joist or wall stud, light pressure will allow the saw to follow the stud. Then go back with a screwdriver and pry off the pieces between the screaws or nails, remove fasteners and your done. Good luck.
Must be in my neck of the woods, Sheryleen. Went using the sawzall, pay attention to where the outlets and lights fixtures are so you won't have any wiring to repair. Also a good idea to pull your main breaker just in case. Sawing through a live wire can ruin your whole day.
Sheryleen here.
Yep, I hear that. Had a lil spark while taking the fan hood over the stove.down,,Whoopie.......I got another saw that will help, not a sawzall. Thanks for the info,,all helps Sheryleen... yes, your neck of the woods
