Replacing wall section(s)
ddayton217's Avatar
01-24-05, 06:47 PM   #1
I took off the tile from my kitchen countertop backsplash and of course a few peices of the wall came out. Do I just run a utility knife around where I want to replace the drywall and cut to fit a piece before I re-tile the backsplash?
coops28's Avatar
KS
01-25-05, 05:15 AM   #2
Yes, that should work fine. You might want to pre fill any large cracks before you set your tile.
kdomg's Avatar
02-01-05, 11:00 PM   #3
kdomg
holes
You might consider using green board if you are in a wet spot. A wet spot is anywhere that you expect that water or moisture may come in contact with the sheetrock.
