removing panelling glue
Old 03-22-05, 08:17 AM
aangela
Unhappy removing panelling glue
can anyone help? After removing woodchip from lounge walls, I have come to a stand still. There are large patches of what looks like resin (from wood panelling I presume) all over 1 wall, and no amount of sanding will shift it - HELP!!
Old 03-22-05, 01:57 PM
awesomedell's Avatar
Best bet would probably be to try using a heat gun to heat of the glue and then scrape the glue off the wall.
Old 03-28-05, 05:20 PM
Do it Dan
i had this problem as well. the panelling was glued to the brick wall???????
anyways i used a heat gun and that worked well on the thicker stuff.
DAN
