Cement Stairway Issues
electric1's Avatar
03-26-05, 08:58 PM   #1
I am remodeling a room that has concrete stairs leading from below. What I want to do is to build a half wall on the ledge of the concrete of the floor of the room that I am remodeling. How do I construct such a thing? I am familiar with building full-sized walls, but half-walls I need a little advice on. Is there a specific name for a half-wall? It would make it a lot easier to research on. Thanks! Pictures of the exisiting stairs below.
Stairwell Pictures
Doug Aleshire's Avatar
AZ
03-26-05, 09:08 PM   #2
electric1,
It's a keewall.
Since you know how to build a wall, this is just a shorter wall. Unsure if you have an end wall to anchor to but this can be installed different ways.
The floor is concrete?
electric1's Avatar
03-26-05, 09:12 PM   #3
Yes, there is an end wall to anchor to.
And yes, the floor is concrete.
Also, keewall returned literally no results in google. I'm guessing you meant kneewall?
AZ
03-26-05, 09:18 PM   #4
electric1,
You have a couple of options - one is to make a double bottom plate - offset at the open end. Use lag bolts/washer and lead anchors. Drill in concrete and install anchors - this will make for a sturdy wall at the open end.
Other is to use these
https://www.confast.com/products/thunderstud-anchor.asp
Does this help?
electric1's Avatar
03-26-05, 09:22 PM   #5
I think I know what you're saying. But will the wall wiggle at the top corner that is not anchored?
AZ
03-26-05, 09:28 PM   #6
electric1,
You may have some minor movement but the next best thing would be dowel screws and use a 4x4 on the very end. Drill a hole in concrete and insert an anchor and then predrill dead center in 4x4 - this will be a long screw. This is similar to custom stair railings. You may want to consider this but you will not get a solid - no wiggle end. It would be very slight.
Hope this helps!
AZ
03-27-05, 05:12 AM   #8
electric1,
This is the best that I could find to help you. Consider the dowel screws and an inside metal corner bracket. What they show is a shallow bracket but you can get one that would be a 4" x 4" of 6" x 4". Attach this to the 4x4 post I mentioned then lay your plate down, anchoring that to the concrete floor. Build your half wall and drywall. This will be very sturdy.
http://www.rockler.com/ecom7/product...ner%20brackets
Hope this helps!
electric1's Avatar
03-27-05, 06:25 AM   #9
Ok, thanks for your help!
