Lowered Ceiling
tobja's Avatar
05-08-05, 09:29 PM   #1
Lowered Ceiling
Hi All,
I want to lower my ceiling in the back room as Im turning it into a half bath/laundry room, and on first look I was going to use battens against the walls on 3 sides (as on the other side I have a window).
The room is 6 x 11 but was going to go to 4 x 11 then "angle" the other 2 ft upwards to over the window to allow light in.
For the battens I was going to run 2x4 up onto my battens at 12" spaces. I will then screw and glue the wallboard to the 2x4 and install recessed lighting.
Would this be feasible? Do you think the ceiling would stay up?
Thanks in advance
coops28's Avatar
KS
05-09-05, 08:00 AM   #2
why are you lowering your ceiling? How much do you want to lower it??
tobja's Avatar
05-09-05, 04:19 PM   #3
Its currently 9.5 ft at the moment so I was looking to bring it down a little bit.
I think I may leave it as it is and just screw up some new wallboard, however I think the ceiling may be sagging which will make the job a bit harder - hence me thinking that I may put battens up for a clean start.
