replacing wall ac grill
Old 05-25-05, 08:00 AM
lesb
I have an old a/c grill on the wall that you can not find filters for. and I am needing to do sheetrock repair, how do I do it?
Old 05-25-05, 08:05 AM
pgtek's Avatar
hi
first do you have this thing connected to the ac and is there any air comming out from it
is it a ac cold air return or a ac register like the furnace tyupe
would help for more info
pg
Old 05-25-05, 08:07 AM
lesb
its the grill on the wall that holds the air filters in place.
Old 05-25-05, 10:31 AM
Welcome to the forum
I assume that it is still connected to the ac unit. I also assume you are replacing it with one you can find right size filters for. If that is so you need to make sure that you have one close to or a little more sq " of filter area so as not to starve the furnace of fresh air.
Drywall repair is easy. If necesary nail or screw new drywall in place. Take a broad knife and smear an even coat of joint compound over the gaps and smooth joint tape on the mud cleaning off the excess with the knife. When dry apply another coat of mud, repeat until it looks good. It normally takes 3-4 coats with sanding on the last 1 or 2.
