large crack in plaster wall
Old 06-01-05, 06:19 AM
dtjewel
Hi, I have a home built in the 50's. In the living room on an outside wall there is a large nasty crack from a piano window almost to the floor. The crack/wall is bubbly. How can I tell if this is just a simple(?) fix to the plaster or could it be a more serious problem? If it's just a simple fix where do I start? Thanks.
Old 06-01-05, 11:03 AM
pgtek's Avatar
might be water leakage behind the window.
I would check for leakage first
you could get some durabond 90 mix it up and applied to fill the crack
