Plaster Chipping off Wall Corners
Old 06-08-05, 08:55 AM
Jenafur
We have drywall in our house, and in the corners, I'm seeing the plaster chip off from the corners. Under this are metal joint strips. My question is: How do I repair this? Do I use joint tape? What do I use over the joint tape to refinish the walls? And how do I make the corners smooth and sharp?
Old 06-08-05, 07:39 PM
The edge of the corner bead should have little or no mud [joint compound] on it. You apply mud over the corner bead using the edge as a guide. It may take several coats. Sand smooth and paint.
Old 06-19-05, 03:07 AM
and for afterwards you could buy those clear plastic "corner guards" if you're so inclined (at HD). They just protect the corner from chipping - good if you have kids...
